Do you really need distilled...
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by 99monguse, Feb 18, 2011.
  1. 99monguse
    99monguse Birth of a Detailer
    What is the basis for having to use distilled water in your IPA dilution?
  2. rfinkle2
    rfinkle2 DB Forum Supporter
    Low to no mineral content is distilled water's advantage. It may not be as crucial in IPA wipedowns as it is whenever water is left to dry on the paint.
  3. Emile
    Emile Welcome to Detailing
    It's a good idea if you plan to store the IPA/water solution for a long time before using it again. If you're going to dilute only what you will use on the spot, then regular water is fine.
  4. 99monguse
    Can you still buy distill water at the grocery store, or wherever?
  5. rfinkle2
    Yes. if it's not in the drinking water aisle, try the cleaning solution aisle.
  6. Denzil
    Denzil DB Forum Supporter
    You can purchased distilled water from Target also.
  7. TheRustySuper
    Pretty much anywhere should have it, and for cheap. I get mine at Walgreens, something like $0.99 a gallon.
  8. Greg Nichols
    Greg Nichols Birth of a Detailer
    If you used Distilled or Reverse Osmosis water with your chemicals they will be much more effective, period. I also use it in my steamer and extractor.
    The cheapest way to get it is my grocery stores have RO water refill stations I take my 10 gallon jugs fill them up for 49 cents a gallon!
    So the answer is yes use it for the best results possible
    Cheers,
    GREG
  9. JPerrydore
    JPerrydore Birth of a Detailer
    Definitely want to use distilled water in any equipment that uses a heating element. Such as your steamer, carpet extractor, or even your iron. You'll end up with mineral scale if you use tap water and will the equipment will fail much sooner than it should.
  10. Whip Appeal Neil
    Whip Appeal Neil Jedi Nuba
    like everyone is saying low-to-no mineral count. I personally dont want to go out and buy the gallon of distilled unless i plan on using it for heavy cleaning. However, and this may sound funny, i use my Brita water as it is somewhat demineralized and more cost effective. I usually just use it to fill up my bottles. However I have heard if our using non-distilled +70% alcohol vs the 92%, to use 2:1 concentration to be more effective. I have not tried this as i just use a 50/50 brita and 70% and it yeilds great results.
