Garage Paint
Discussion in 'Detailing Bliss Lounge' started by Rcrew, Sep 26, 2012.
  1. Rcrew
    Rcrew Wax on..Wax off
    I am going to be spraying my new garage this week and my initial reaction was to get a paint that is as white and as glossy as possible to improve reflection of light. What have you guys found is the best type of paint to use in a garage where detailing will occur?
    Will the higher gloss paints show off any imperfections in the sheetrock taping/mud and framing irregularities?
    TIA
  2. SoCal Garage
    SoCal Garage DB Forum Supporter
    Are you going to texture your walls and ceiling? If not, you'll likely regret it as the walls/ceiling will not look uniform; finished the inside of your garage like you would a room in your house. I've used bright gloss white and it is usually categorized under industrial as most people do not do use straight whites. If you want the best job rent a commercial grade paint sprayer, mask and tape all the areas to be unpainted, purchase five gallons paint buckets.
  3. Stokdgs
    Stokdgs Detail Master
    "Will the higher gloss paints show off any imperfections in the sheetrock taping/mud and framing irregularities?"
    Yes, the glossier the paint finish, the more any imperfections will be visible, especially if the walls are not textured. If you can totally install, mud/tape the drywall so perfectly, then you are truly the Masta' This is why they invented texture and flat finishes. :)
    I personally have bright white flat paint in my garage and dont have any trouble seeing stuff. I am not sure I would want a glossy paint that reflects light into my eyes as well as the vehicle/s in the garage.
    Have you looked at pictures or seen a glossy, shiny, garage walled garage already?
    Good luck with this !
    Dan F
  4. Pureshine
    Pureshine DB Pro Supporter
    I did flat white with good lighting and works perfect.
  5. Rcrew
    Thanks all. Read up a bit on a garage forum and they agree with the sentiment here...gloss is a bad idea.
  6. vtec92civic
    vtec92civic Nuba Guru
    Hot Pink would be sweet LoL. Just kidding
  7. Rcrew
    With some rhinestones! Definitely bedazzled...
