Rigid Shop Vac - 9 gal 3.5HP for $25 on Black Frid
Discussion in 'Sale, Trades, or Bargains' started by spK, Nov 18, 2008.
  1. spK
    spK DB Forum Supporter
    Hey guys, black friday is coming around the corner! Some of you guys might be interested in a shopvac.
    Home depot will have a Rigid 9gal 3.5HP for $25+tax.
    Go here and download the pdf: LINK
    I just bought a craftsman 9gal 4HP vac from sears for $40, don't know if I should return it and get the Rigid or keep it. Will that extra .5HP for $15 be worth it?
    Feedback appreciated!
  2. P1et
    That is suuuuuuuuuuuuuuuuch the bargain!!!
  3. Buddy
    I wish I could remember the name of the company but the same company makes the rigid And the Craftsman Shop vacs...:shrug:
  4. spK
    I think I'm going to return my craftsman and get this rigid then. .5HP less but its a lot cheaper
  5. heatgain
    heatgain Guest
    I'm only guessing, but shouldn't the minimum HP for a detailer be 5 HP? I'm thinking about the power necessary to 'extract' wet carpet and seats.
  6. Charlies02GLS
    Charlies02GLS Jedi Nuba
    Honestly the horsepower rating on alot of vacuums and compressors are nearly meaningless. It depends on whether the advertiser slaps on the peak value, or what it uses while running etc..
    For example, that vac advertises 3.5 peak horsepower but since it draws 9 amps @ 120 V the actually running horsepower would be (120Volts*9Amps)=1080Watts*(1hp/746 Watts)=~1.45hp. The most you'll ever get out of a standard 15amp circuit would be about 2.4hp and that's assuming 100% efficiency for the motor.
  7. Showroom Shine
    Showroom Shine Birth of a Detailer
    WOW! Thanks for the info. I'm looking to purchase another vac. The one I have the moter is starting to hum when it slows down. I guess thats a sign it's about to go. I hate to be in the middle of a job and a piece of equipment stops. Sucks! Any good suggestions for a good ,light compact vac that is good for detailing. I'm researching a good strong one,it does not have to be cheap either!
  8. Buddy
    AGREE - You are so right. If you had a 5 horse power vacuum for real. never mind the electricity you would have to install. You wouldn't be able to lift the dam thing...This is true...:yikes:
  9. Charlies02GLS
    Wish I had a suggestion, I've read good things about Metro vacs but I don't have any first hand experience with them. I personally use a 16gal mid-80s era craftsman shop vac rated at 11amp/120 volts. I guess I'd say just visit websites and look up the specs.
  10. racersky
    racersky Jedi Nuba
    haha i'm definitely trying to get this but do you have to wait in line for black friday? I never done it but this year i heard it's going to be in the mid 20s aronud my way
  11. P1et
    I do not think that there will be crazy demand for shop vacs, so if you don't get there at 4am, you should be fine!
  12. racersky
    racersky Jedi Nuba
    Kinda odd I got to home depot at 7:45 and there was four left on the pallet. :headbang:
  13. DG 501
    DG 501 Jedi Nuba
    Congrats! It's all the women shopers that are nuts enough to go out at some... crazy hour and get those deals Like P1et said... not too much demand for shop vacs. Congrats!!!
  14. racersky
    racersky Jedi Nuba
    I'm cleaning u my garage to have it organized for myself....trying to figure out how to cut this annoying table. Anyways I was talking to an employee at the home depot I went to and the guy said that they had 16 vacs on that pallet and it was mostly gone to construction workers so they can connect that to their ridgid table saw.
  15. DG 501
    DG 501 Jedi Nuba
    Good luck with the organization process!
  16. racersky
    racersky Jedi Nuba
    lol dammit i need a saw to cut this table an half....apparently the people who used to live in this house threw their dining room table in the garage and left it there
