476 application
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by Atom Bomb, Mar 29, 2010.
  1. Atom Bomb
    Atom Bomb Two Bucket System Washer
    Hey All,
    I have searched and couldn't find quite the answer I was looking for. I was wondering what your steps are for applying Collinite 476 to the car. I am going to use it by hand with a yellow applicator pad (also have some Zymol Wax App). The wax seems really hard...just wondering if I should put it under the halogens for a bit to warm it up. How long should I let it sit on the panel before wiping? Really hoping for everyone's personal opinion.
    Thanks, really learning a lot here :)
    -Jon
  2. P1et
    476 isn't as easy to apply and remove as 845. Personally, I would rub the wax until it's got a layer of "liquid" on top that you can dab your applicator in. Don't let it sit more than about a minute.
  3. pektel
    pektel DB Forum Supporter
    +1. pretty much wipe on off.
  4. Dannyk
    Dannyk Jedi Nuba
    Been having the same scenario also, so i applied the 845 first since it goes on so easy and comes off so easy. Then i go back over with the 476s, works just like the 845 that way.I know of the extra step involved, but that extra step means something to the client as well as to me.
  5. Atom Bomb
    Interesting...should I dampen the pad as well like other waxes?
  6. christian900se
    It is not a difficult wax to use by any stretch of the imagination; it will spread pretty well and as long as you use thin applications, will remove just as easily. I normally let it sit for 30 minutes in most cases and I have never had an issue with removal, but it does come off slightly easier if you apply and remove in quick succession.
    Dry pad is fine; once your pad is loaded with product, it will spread easily and go a long way.
