Hello, I've polished my car with Adam's Swirl & Haze remover. It took pretty much all of scratches out, though some are still remaining. Next time I will get to polishing the car, I'm thinking of using a stronger compaund to take care of them. In light of this, how much cut Adam's SHR has compared to Menzerna polishes? Which one does it most relate to and which ones have more cut? Thank You!
How many times did you do each section to remove the swirls? What pad did you use? Adam's/Lake Country. You can back again and it will remove more swirls. How much depends on the depth of the swirls. In the end you are just removing paint. A more aggressive polish will just do it faster.
Problem is my car has single stage paint on it, no clear coat at all. I'd rather do a small patch with a more aggressive compound then constally go over it with SHR. Not slamming SHR, it worked great to remove small swirls and scratches... P.S. I used Uber pads from Detailers Domain... Thank You!
