DA polishing technique
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by vasaline, Feb 24, 2012.
  1. vasaline
    vasaline Two Bucket System Washer
    What is everyones polishing technique when using something like 106FA and a uber green pad? For example do you reduce machine speed and pressure during the last few passes or do u just maintain the same speed and pressure thoughout the whole buffing cycle?
  2. chemgys99
    chemgys99 DB Forum Supporter
    I usually reduce speed and pressure last couple passes. But I don't think it's as important to do that with a orbital then it is with a rotary.
  3. GDAL
    GDAL Super Moderator
    I reduce the speed when I use dimishing polishes ... I don't with SMAT polishes.
