Reviews:Meguiars;Detailers Domain;Eshine;3M& more
Discussion in 'Car Detailing Product Discussion' started by Deep Gloss Auto Salon, Aug 3, 2008.
  1. Deep Gloss Auto Salon
    Ok, just some quickies after extensive usage..
    1z Klima Cleaner: This stuff is great; I have used it on 3 different vehicles with stellar results. The scent is a light lemony scent. Nothing obnoxious. The directions call for a complete can to be used on each vehicle so to make it worth it a simple $30 up sell is required and a nice addition to the bottom line
    Eshine Kleenol APC: I have to say I really love this stuff. I received a beta sample from Eshine and I have used it for different things at different ratios and it has yet to let me down. I think the most impressed I have been with this stuff was when I have used it to clean exterior plastic trim.. One of my customers had some wax or something on his trim and NOTHING I had was getting it off.. I pulled out the Eshine Kleenol APC diluted 4:1 and it knocked it out on a flash!
    Detailers Domain Uber Towel (16x24 blue): I this towel is my new go to towel for polishing and wax/sealant removal. It has just enough *bite* to do the job with ease and yet, it still *uber* soft. I picked up 15 and really need another 20!!!
    Harbor Freight Wheel Brush: What I like about this brush is the small circumference of it making it easy to get into the barrel, even in the caliper area of most wheels. One thing to mention is that the bristles are pretty rough so you must be gentle as to not damage the finish of the wheel. My main use for this towel is to wrap it with a micro fiber towel, spray it with a quick detailer (I use Surf City Hot Rod Detailer) and I then get into the barrel to clean up anything that is in there.. If I use a thin towel I can get around the entire barrel.. I love this little trick
    Rejex: This is my new go to sealant for rims. Now it is not as easy on/off as a spray such as Duragloss Aqua Wax BUT in my opinion AW is not substantial enough for true protection on the rims. I need something that is just going to afford me with a method to simply rinse off any dust, dirt etc.. Rejex fits this order and really provides a very impressive shine!
    Eshine Glass Thief Towel: This towel is simply the best towel I have used for windows. Previous to the glass thief my towel of choice was a waffle weave micro fiber.. While it did work very well, they would lint just a small amount during use and it would drive me NUTZ!!! Well, due to the almost suede feel of the Glass Thief they DON’T SHED LINT.. A very important factor when you don’t want to be squandering time to get lint off of windows.
    Meguiars 105 Ultra Cut Compound: What can I say; this stuff has made the rounds on many forums and for good reason. It cuts fast and hard. The thing is you must re-learn EVERYTHING you have ever learned about machine polishing you don’t:
    •Start the machine speed off slow
    •Speed up
    •Break it down
    •Slow down the speed of the machine​
    I start off at 1100 RPM, put some 105 on the paint, start compounding and count to 13, if the compound after 13 seconds comes off easy, that tells me I may be able to work it longer SO, I bump the speed up to 1300 and still count to 13. If the compound still comes off easy I try it again on speed 1300 BUT count to 16 if it still comes off easy I bump up to 1500 RPM and count to 16. if it still comes off easy I up my count to 20 and still use 1500 RPM.. Once any of the above steps makes the compound come of with difficulty I go to the last method that the compound was easy to remove.
    This product really talks to you by how hard/easy it is to remove. If it’s a pain to remove, that means you worked it too long or too fast or both.
    3M Ultra Fina SE: I have been using this more and more and it has been hard to do so. Why has it been hard you may ask, WELL because I am just so in love with my Menzerna 85rd and FP!! In an effort to expand and grow I have been using the UF more often. I find it much easier and faster than 85rd but I also find it has a little less cut. I have also noticed that the gloss level does not seem to match that of the 85rd.. BUT it is just such a pleasure to work with, I really love using it with the blue 3M pad that was made to be used with this product.
    Meguiars W66 Backing plate: Even though I *but the bullet* and purchased the expensive 3M UK backing plate I decided I owed it to myself to see what the W66 was all about.. I have to admit I am impressed!! I have been using this backing plate with my 6.5: lake country purple foamed wool and it is GREAT.. I find it just as easy and workable as the 3M UK backing plate. I used the Meg’s backing plate yesterday with foam for the first time and it was equally as great as the 3M UK BP.. I mention the foam being used yesterday because wool is much easier to control with the rotary so using foam with the W66 for me was the last test.. AND IT PASSED!!
    Norton Painters Tape: I picked this up at my local automotive paint supply store on the recommendation of the owner. It is half the cost of 3M green painters tape and performs JUST AS WELL if not better.. How could it perform better you may ask, well thus far, I have noticed less residual adhesive transfer onto the paint. It looks like masking tape in color and at first I didn’t want it but he gave me some for free and told me “you’ll be back for more”… well, he was right
  2. Scott's Mobile Detailing
    awesome! Thanks for he reviews!
  3. JLs Detailing
    Great reviews there bro! Thanks for that. I am a little different when it comes to 3M UF though in that I haven't even touched my bottle of 85rd since I got my UF. Great info and you have some products I need to try out.
  4. er1k
    er1k Obsessive Detailer
    Great reviews! Thanks.
  5. yukonon22
    yukonon22 Wax on..Wax off
    nice reviews
  6. Brian N
    Brian N Jedi Nuba
    Awesome post! Thanks for explaining in depth technique for M105.:thumb:
  7. Deep Gloss Auto Salon
    Glad you found it of value:thumb:
    Thanks JL!
    What is it about UF SE that you prefer over 85rd? Is it just the ease uf use, because I will admit that it is easier to use and has less of a learning curve...Just wondering...
    :afro:
    :thumb:
    Thanks Brian... Hope you have luck with M105!
  8. JLs Detailing
    To me it is much easier to use and I just don't think 85rd gives really anymore Wow factor to the gloss than UF so I reach for the UF everytime.
  9. Deep Gloss Auto Salon
    Gotcha.. I agree it is easier to use and faster.,.. maybe the amped up gloss I see is all in my head...lol
  10. zoomzoom mazda5
    Thank you for the review Jason......:thumb:
  11. eyezack87
    eyezack87 Guest
    Good review. I also thought Klima clean was a great product :)
  12. krshultz
    krshultz Nuba Guru
    Thanks for the excellent reviews. Agreed on the Uber towels - they're "just right." And I'm pleased to report that they're very, very long lasting. Phil threw one in on the last few orders I placed, and I've been using them a LOT. So, I just ordered another ten of them when he had that killer sale.
    If you don't mind, what is so special about this 3M Euro backing plate? I haven't found any fault with the plate I got from Phil - however, I've never tried anything else, so I might just not know the difference.
    What a great website. Probably the only forum that I've found that I know I can learn something useful just by going back several pages and reading.
  13. dsms
    dsms DB Forum Supporter
    Must look into that tape!
  14. Chris
    Chris Two Bucket System Washer
    I used a can of the1z Klima clean on a good customers car that the air just seemed a little stale in. I didn't even mention it to him just to see if he would notice. He noticed and gave me a call about it he said he had noticed that the air had been a little odd lately and that it seems to have made a big difference. I see the car at least once a month so I will get the chance to see how long it lasts.
  15. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Jason how does the 1Z Klima Cleaner compare to BG Friggie Fresh. I would imagine you have access to it since you are in the auto industry also.
  16. Denzil
    First of all, thanks a ton for your multiple reviews of many products!
    I'm definitely interested in trying out some of that eShine APC. I'm sure it's awesome stuff.
    The DD Uber Towel is pretty nice but I find that my Excel towels are easily more plush than my Uber towels. Don't get me wrong, the Uber towels are decent towels but not as nice as my Excel Supreme/Elite towels.
    M105 is some great stuff but I'm still learning the technique required for it. I did purchase M95 to experience the differences between the two.
    UFSE is definitely some great stuff and I agree with you. However after reading your review, I'm even more interested in comparing it to 85RD and FP.
    I thought about trying out the Meg's W66 BP at one point in time but since I have already purchased the 3M UK BP, I don't really need it. Then again I may need it as a backup just in case for some odd reason the 3M UK BP fails.
    It was interesting to hear your take on the Norton Painters Tape. Seeing that it is cheaper than the 3M green tape, I'll have to check it out myself once my stock of 3M blue tape has run out.
    Again, thanks a lot for your review Jason!
  17. Strokin04
    Strokin04 Birth of a Detailer
    I agree with you on the W66 backing plate being real nice to use with the rotary.
  18. supercharged
    awesome reviews, dude!
