i got a hold of some swissvax concourso and cleaner fluid. what is the best way to go in applying the wax for maximum shine and protection. 1. wash. 2. clay 3 wash again 4. swissvax cleaner fluid 5. then 6. then 7. swissvax concourso 8. done this will be the first time i have used swissvax and would like to know if any different approach compared to other products. i do this with poorboys products. of course, wash , clay, professional polish, black hole glaze, ex-p, then nattys red or blue. what do other swissvax users do in their detail process?
There is really no difference that I have read in dealing with SV and other wax's. Just do your normal routine and last step should be the cleaner fluid followed by the SV. I would do 3 coats for best shine and depth. Just do what you have said you normally do but stop after pro-polish and then do the cleaner fluid instead of the glaze and then apply the wax.
ok thank you for the recommendation. just wondering would there be any problems using two different products. if i use Poorboys then swissvax or menzerna first then swissvax.
there shouldnt be any problem...poorboy n menzerna for paint correction, then cleaner fluid for prewax cleanser before concorso Hope it helps
Hi..you will enjoy using SV.... wash car with Car bath Than paint rubber with Quick finish for lube cleaner fluid strong (if the condition of the paint is swril and oxidation) Cleaner fluid medium to clean off any haze that cause by cleaner fluid strong Cleaner fluid for last step before applying wax Make sure all cleaner fluid was completely removed before wax is apply. than apply wax ,use thin layer rather than heavy coat, and wait at least 30 mins before removal, and try to leave it under the sun. You will notice , the car look more darker. If you need more help.please PM me
SvPro i am a little lost on the soft, medium, and strong cleaner fluid. Can the cleaner fluid be deluted?
strong, medium and regular cleaner fluid that you have are all different products. Strong and medium are abrasive polishes like Menzerna, Poorboys SSR's. They are SV's line of polishes to remove swirls marks and scratches. The cleaner fluid that comes in the black bottle that you get from DD is a true cleaner fluid/paint prep fluid that cleans the surface of oils and polish readue and leaves behind a nice surface for the wax to bond to. You can use any abbrasive polish to remove swirls that you choose, then follow with cleaner fluid, and 3x of the wax.
